W:Failed to fetch http://ppa.launchpad.net/shakaran/ppa/ubuntu/dists/precise/main/source/Sources 404 Not Found
W:Failed to fetch http://ppa.launchpad.net/shakaran/ppa/ubuntu/dists/precise/main/binary-i386/Packages 404 Not Found
E:Some index files failed to download. They have been ignored, or old ones used instead.
Asked
Active
Viewed 178 times
-1
Richard
- 8,588
This means that you added an PPA (repository that is not supported by Cannonical), and the PPA is unreachable. To fix, simply remove the PPA: edit the file /etc/apt/sources.list and remove this link from the file. You will need root (sudo) to save after you are done.
Cheiron
- 318
You have added PPAs that are dead, or unreachable for some clause, happened to me before too, it is not a big deal, nothing to be afraid of, you can fix this bu removing the PPAs from your software sources or use :
sudo add-apt-repository --remove ppa:PPANAME
sudo apt-get update
Now i left PPANAME beclause i dont know the exact name of the PPAs, anyone edit me freely
fi40
- 78
