-1
I received my copy from a friend, and when I try to upgrade, it keeps saying there is a problem with my Internet connection, but I can access everything online.
Also I can not install anything so please help thank you.
I don't know much about Ubuntu, I just like how stable it is.
Tim
  • 33,500
Hmm, first try this : Go to Applications > Accessories > Terminal
Now write the next :
sudo apt-get update
And hit enter, after finish write this and hit enter :
sudo apt-get upgrade
And then write and hit enter :
sudo apt-get dist-upgrade
That should work,maybe you will be asked to type y or press enter later
If that doesn't work go to the update manager and click settings, from then find the " Download from : ____ and see if the place typed in the blank space is nearest to you, if it is not then change it and try again, hope it helps :D
Or try this
fi40
  • 78
