I have tried everything, but nothing works...
Background: Started out with Windows 7, formated and installed Ubuntu and later installed Arch linux with a GPT partition table.
Running following commands from Ubuntu 12.04 Live USB.
Starting with: Have Arch Linux installed with four partitions. Using GPT.
/dev/sda1 Root partition
/dev/sda2 BIOS boot partition
/dev/sda3 Swap partition
/dev/sda4 /home partition
Step 1:
sudo parted /dev/sda
mklabel msdos
Get the "GPT signatures found"-error message then I check.
Step 2:
sudo dd bs=4M if=/dev/zero of=/dev/sda
Still get the error message.
Step 3:
sudo dd bs=1M if=/dev/zero of=/dev/sda
Still get the damned error message about GPT signatures found.
Step 4>
mktable msdos
I'm not giving up! Even this doesn't work, and the error message appear.
Output from sudo fdisk -l:
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x0004cb5a
Device Boot Start End Blocks Id System
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 2103 MB, 2103443456 bytes
255 heads, 63 sectors/track, 255 cylinders, total 4108288 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x71bafca0
/dev/sdb1 * 0 1607679 803840 0 Empty
/dev/sdb2 1595952 1600495 2272 ef EFI (FAT-12/16/32)
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb1'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb1: 823 MB, 823132160 bytes
255 heads, 63 sectors/track, 100 cylinders, total 1607680 sectors
/dev/sdb1p1 * 0 1607679 803840 0 Empty
/dev/sdb1p2 1595952 1600495 2272 ef EFI (FAT-12/16/32)
Output from sudo parted -l
Model: ATA ST250LT007-9ZV14 (scsi)
Disk /dev/sda: 250GB
Sector size (logical/physical): 512B/4096B
Partition table: msdos
Number Start End Size Type File system Flags
[GPT-Signatures-found error message]
What should I do to remove the last fragments of the GPT table? Trying to reinstall Arch again, but can't use cgdisk to create partitions.
Your fdisk and parted outputs both indicate that you've got two disks: /dev/sda and /dev/sdb. The "GPT data" error seems to be coming from /dev/sdb. I recommend running FixParts on this disk. This program is part of the gdisk package, which you may need to install. If it detects stray GPT data, it will ask you if you want to remove it. You can then exit from FixParts without making any more changes. You can also try running FixParts on /dev/sda, but I suspect it's completely clean of stray GPT data.
Incidentally, Richard is correct about GPT storing a second copy of its data at the end of the disk; but given the steps you've taken and the output you've shown, I don't think you're seeing the effects of that data on /dev/sda; I think you're seeing stray GPT data in sectors 1-33 (and probably at the end of the disk) on /dev/sdb.
Rod Smith
  • 45,120
  • 66
  • 108
