Okay here's the question:
Ubuntu 12.04 Precise will not shut-down it just Reboots again!
Its as simple as that. I have tried every command out there and not a single one of these commands works in grub or Ctrl + Alt + T or any other method suggested.
  1. sudo shutdown -p now <-This does not work
  2. Type in terminal:
    sudo -i (to get a root shell, sudo gedit is not recommended)
    gedit /etc/default/grub
    Find the line: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
    • Change this to: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=force"
    • Save the file and close the file.
    • Finally, in terminal: update-grub
    • exit (to end the root shell) <-This does not work
  3. sudo poweroff <-This does not work
  4. alt + F2 and type gksudo poweroff <-This does not work
  5. Code:
    sudo gedit /etc/default/grub
    --> remove quiet splash, then :
    sudo update-grub
    before trying to shut down again, run:
    sudo apt-get install --reinstall ubuntu-desktop
    sudo dpkg-reconfigure -phigh -a  <-This does not work
  6. halt or shutdown -h now <-This does not work
  7. sudo init 0 <-This does not work
  8. acpi=norq added to grub <-This does not work
  9. Typing shutdown or restart in Dash Home <-This does not work
  10. sudo shutdown -h 0 <-This does not work
  11. sudo halt <-This does not work
  12. sudo shutdown -h 0 <-This does not work
So lets try to figure it out together, lets solve it since no updates are coming in to fix it!
Alaa Ali
  • 32,213
Ray
  • 81
