I wanted to run my Dropbox daemon automatically at start-up. I did it via terminal, that is, I (1) moved it to /etc/init.d, (2) made it executable, and (3) ran sudo update-rc.d dropbox.sh defaults. So we have
$ ll /etc/init.d/dropbox.sh
-rwxr-xr-x 1 root root 38 Aug 16 00:18 /etc/init.d/dropbox.sh*
$ cat /etc/init.d/dropbox.sh
#! /bin/sh
~/.dropbox-dist/dropboxd &
$ ll ~/.dropbox-dist/dropboxd
-rwxr-xr-x 1 skrd skrd 258 Jun  6 03:03 /home/skrd/.dropbox-dist/dropboxd
However, Dropbox does not run upon start up.
Note that, invoking /etc/init.d/dropbox.sh runs the dropbox daemon without hitch.
I know that Ubuntu has a GUI for this and I could easily just add the dropbox script there but I wonder why my terminal commands didn't do it? Isn't that more standard for Linux machines?
It may be a good way if you use insserv instead of sudo update-rc.d dropbox.sh defaults.
sudo insserv
From man insserv:
insserv  is a low level tool used by update-rc.d which enables an installed sys‐
tem init script (`boot script')
If you get the command not found error, you may fix by running the following command:
sudo ln -s /usr/lib/insserv/insserv /sbin/insserv
See insserv -h for help.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
