-1
I am new to Linux, and I keep encountering problems when I try to install or remove software. Does anyone happen to know what the problem is?
The errors read:
installArchives() failed: (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 348502 files and directories currently installed.)
Removing libreoffice-base ...
Processing triggers for man-db ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for mime-support ...
Setting up linux-image-3.8.0-25-generic (3.8.0-25.37) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.8.0-26-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.8.0-25-generic /boot/vmlinuz-3.8.0-25-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.8.0-25-generic /boot/vmlinuz-3.8.0-25-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.8.0-25-generic /boot/vmlinuz-3.8.0-25-generic
update-initramfs: Generating /boot/initrd.img-3.8.0-25-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.8.0-25-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.8.0-25-generic.postinst line 1010.
dpkg: error processing linux-image-3.8.0-25-generic (--configure):
 subprocess installed post-installation script returned error exit status 2
No apport report written because MaxReports is reached already
Setting up linux-image-3.8.0-26-generic (3.8.0-26.38) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-3.8.0-25-generic
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.8.0-26-generic /boot/vmlinuz-3.8.0-26-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.8.0-26-generic /boot/vmlinuz-3.8.0-26-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.8.0-26-generic /boot/vmlinuz-3.8.0-26-generic
update-initramfs: Generating /boot/initrd.img-3.8.0-26-generic
update-initramfs: failed for /boot/initrd.img-3.8.0-26-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.8.0-26-generic.postinst line 1010.
dpkg: error processing linux-image-3.8.0-26-generic (--configure):
Setting up linux-image-3.8.0-27-generic (3.8.0-27.40) ...
Running depmod.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.8.0-27-generic /boot/vmlinuz-3.8.0-27-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.8.0-27-generic /boot/vmlinuz-3.8.0-27-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.8.0-27-generic /boot/vmlinuz-3.8.0-27-generic
update-initramfs: Generating /boot/initrd.img-3.8.0-27-generic
update-initramfs: failed for /boot/initrd.img-3.8.0-27-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.8.0-27-generic.postinst line 1010.
dpkg: error processing linux-image-3.8.0-27-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-3.8.0-27-generic:
 linux-image-extra-3.8.0-27-generic depends on linux-image-3.8.0-27-generic; however:
  Package linux-image-3.8.0-27-generic is not configured yet.
dpkg: error processing linux-image-extra-3.8.0-27-generic (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-generic:
 linux-image-generic depends on linux-image-3.8.0-27-generic; however:
 linux-image-generic depends on linux-image-extra-3.8.0-27-generic; however:
  Package linux-image-extra-3.8.0-27-generic is not configured yet.
dpkg: error processing linux-image-generic (--configure):
dpkg: dependency problems prevent configuration of linux-geNo apport report written because MaxReports is reached already
neric:
 linux-generic depends on linux-image-generic (= 3.8.0.27.45); however:
  Package linux-image-generic is not configured yet.
dpkg: error processing linux-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic-pae:
 linux-generic-pae depends on linux-generic (= 3.8.0.27.45); however:
  Package linux-generic is not configured yet.
dpkg: error processing linux-generic-pae (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-3.8.0-25-generic:
 linux-image-extra-3.8.0-25-generic depends on linux-image-3.8.0-25-generic; however:
  Package linux-image-3.8.0-25-generic is not configured yet.
dpkg: error processing linux-image-extra-3.8.0-25-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-3.8.0-26-generic:
 linux-image-extra-3.8.0-26-generic depends on linux-image-3.8.0-26-generic; however:
  Package linux-image-3.8.0-26-generic is not configured yet.
dpkg: error processing linux-image-extra-3.8.0-26-generic (--configure):
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-3.8.0-27-generic
cpio: write error: Broken pipe
E: mkinitramfs failure cpio 1 gzip 1
Running depmod.
Running depmod.
dpkg: dependency problems prevent configuration of linux-generic:
Pro Backup
  • 3,248
Elijah
You have no more space available in your disk. Try to free space.
sudo apt-get autoclean && sudo apt-get autoremove
delete some unused software:
sudo apt-get remove package_name
Check for old big files that you don't use anymore in your /home:
find ~ -type f -size +10000k -exec ls -lh {} \; | awk '{ print $8 ": " $5 }'
After you have enough free space, try upgrading again.
Braiam
  • 69,112
If you're not comfortable with the terminal you can also try using Ubuntu Tweak for cleaning your disk, download it from here:
https://launchpad.net/ubuntu-tweak
Alfredo CG
  • 46
