15
I'm looking for an app to view photos in folders, which can display properties (like time taken) next to photo. I want to view photos in folders as they are, without importing them to some library like in Shotwell or Digikam.
What would you recommend?
RolandiXor
  • 51,797
amorfis
  • 603
5 Answers5
15
The default photo viewer (eog) will show metadata. If you open your photo, right click and select Properties. It will open a window that lists the metadata. You can then switch between photos and keep the metadata open beside it.
Screenshot
Zanna
  • 72,312
NateW
  • 510
Try
gthumb Install gthumb
It is a powerful image viewer with many awesome features. I'm not sure if it can show the data next to the images, but you don't need to add a library.
If you enable the side pane in eog (View menu - you can get this info at the side as well.
To enable this btw you need to have the exif display plugin enabled in preferences. If you do not have this plugin, install eog-plugins Install eog-plugins.
RolandiXor
  • 51,797
The Nautilus properties option is the quickest way and gives most important data, but it doesn't show things like GPS coordinates if your images have geotagging.
For geolocation info you could try the lightweight Gwenview photo app found in the Ubuntu Software Center.
I also like the pre-installed Shotwell which also shows GPS data.
Zanna
  • 72,312
If you use the Nemo file browser, you can install this collection of Nemo custom actions and related scripts for displaying Exif metadata of media files in Nemo and for plotting GPS position thereof using various online mapping services:
Github-page s-n-ushakov/exif-gps-mapping-nemo
It allows displaying Exif metadata of media files in popup windows in Nemo, as well as displaying shooting locations in DuckDuckGo, Bing Maps, Google Maps (in a browser) ...
Installation
  • download a release archive and unpack to an arbitrary temporary folder
  • open the folder that was created upon unpacking the release archive
  • run the installation script as ./install-for-current-user.bash
Filbuntu
  • 13,891
While Digikam needs a database, it comes bundled with showPhoto (I have v 4.0.0beta3 right now, don't know if showPhoto was available in earlier Versions). showPhoto is a standalone image viewer, without database. It displays pretty much the same metadata as Digikam does. This is a good option for someone who needs both: indepth asset management and a quick viewer with editing features...
Personally I can recommend Gwenview, too. Metadata display can be fully customized and it displays every kind of data.
AnnTi
