15
As a dedicated Ubuntu server or as a VPS, I am looking for a web control panel, something like cPanel which is something like a web administrator for a server.
I have not used any on Linux since I do everything through the terminal, but still want to know what I can use in the case I have to recommend Ubuntu Server with such an application installed.
Eliah Kagan
  • 119,640
Luis Alvarado
  • 216,643
5 Answers5
16
Here is a list of free and paid control panels that are available for Ubuntu server
Free CPanel Alternatives
web://cp
web://cp was where it all seems to have started for much of the open source world. It was written in php and the aim of it's single developer was to make a good quality control panel.
web-cp is an Open Source solution taking up the torch where web://cp stopped and is a direct continuation of that project. Like the original this is written in php and so should put little additional stress on a server. This might be good for you if your server is a little lacking in the power needed to run piles of additional software.
FlexCP
FlexCP is an Open Source solution and so is likely to improve in proportion to the number of users. It can be obtained under the GNU GPL version 2 from sourceforge.net. It is a redevelopment of "web://cp" and as of writing had not released any file packages.
Cube Panel Lite
This is the stripped down version of the non-free Cube Panel. Being closed source there is a lot less that can be easily researched on the subject. I can however tell you that you will be limited to one server and 30 domains. After that yo will be looking for an upgrade or another free alternative.
VHCS
VHCS is an open source solution released under the Mozilla Public License 1.1 (MPL 1.1) and it appears to be a live and ready to go open source solution. For mission critical servers this might be the choice of system for this reason only. It is a sourceforge.net project so downloading should be simple even if installation is not.
And of course
Webmin
Webmin is a free and impressive looking suit of control panel packages. It is free and open source solution licensed under the BSD License according to sourceforge.net. Much like the Fedora and Red Hat relationship there is a non-free version too. The GNU GPL is also used which is a bit confusing for the fussy.
Non-Free CPanel Alternatives
Plesk
After CPanel this is possibly the next biggest system used.
Cube Panel
While "not at all" playing off the CPanel naming this is a commercially viable package. Like CPanel there are three levels of management allowing for reseller accounts but also like CPanel you are going to pay for this. The key advantage here is that you an get a free 20 day trail version to test out prior to purchase. You may also find that the "lite" version has everything you need.
Ensim pro
Direct Admin
While "not a free offering" the lifetime unlimited license is a mere US$299 which, right now, is arround UKĀ£147 (give or take a bit). This comes with 90 days of support which should be enough to get you up and running. Alternatively you can pay by the month for ongoing support.
Virtualmin Pro
The pay for, super "pro" version of webmin's virtualmin for those that want all the power. The webmin site says "Both the Pro and GPL versions are built from the same codebase, so all bugfixes and some new features go into both of them."
VHCS Pro
ServerPilot
ServerPilot is a SaaS control panel for developers hosting their websites on Ubuntu servers. The basic server configuration and security functionality is free. The paid plans offer advanced features and monitoring.
Source:LordMatt
Sam Denty
  • 103
Mitch
  • 109,787
I'm using ISPConfig in my staging development server since years and works just fine!. It's actively developed and really easy to install and use. It allows you to select between nginx or apache webserver, and also has support for several PHP versions. It has control of users, domains, resellers and even virtual machines!
It has a very comprehensive free support channel through HowToForge forum https://www.howtoforge.com/community/#ispconfig-3.23 and site https://www.howtoforge.com
You can find more here http://www.ispconfig.org/page/home.html
Here is a very detailed installation procedure for Ubuntu Server LTS 14.04
In the documentation page of the project you will find lots of other setup instructions for other distros http://www.ispconfig.org/page/en/documentation.html
Hope it helps!
razor7
  • 1,589
I reccomend you to try ISPmanager.
Yeah, it's not free but price is much lower than for cPanels. The panel has all features that premium panels has. It's even has buil in PHP selectro, which is actually really usefull.
Business version has integration with CloudLinux, so you can provide stable shared hosting with it!
What's more intresting is that this panel has only one price for both VPS and Dedicated Server, so you won't overpay if you uses phisical server.
GUI is pretty simple, you could see it by using Live Demo or checking snaphot of the panel.
Vhcs should be reached here, http://vhcs.sourceforge.net/ The other link is old. And cube panel is not available no more.
I would add this as a comment to Mitch's answer, but alas not enough reputation.
I have another that can be added, it has free and paid versions:
Webuzo
Webuzo is a Single User Control Panel which helps users deploy Web Apps (WordPress, Joomla, Drupal, etc) or System Apps (Apache, NGINX, PHP, Java, MongoDB, etc) on their virtual machines or in the Cloud. Webuzo enables you to focus more on using applications rather than maintaining them. Webuzo is also available in the form of Virtual Appliances.
