Wi-Fi is not working for my Ubuntu installed on Windows 7. However it's working when shifting to the Windows environment. I have dual operating systems on my machine.
Here are outputs of a few commands:
lshw -C Network:
*-network UNCLAIMED
description: Network controller
product: BCM43228 802.11a/b/g/n
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:f7e00000-f7e03fff
*-network
description: Ethernet interface
product: NetXtreme BCM5761 Gigabit Ethernet PCIe
physical id: 0
bus info: pci@0000:0c:00.0
logical name: eth0
version: 10
serial: b8:ca:3a:c4:3f:dd
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.123 firmware=5761-v3.80 latency=0 link=no multicast=yes port=twisted pair
resources: irq:44 memory:f7c10000-f7c1ffff memory:f7c00000-f7c0ffff
Output of:
rfkill list all:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Output of:
ifconfig
eth0
Link encap:Ethernet HWaddr b8:ca:3a:c4:3f:dd
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:18
lo
Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:6446 errors:0 dropped:0 overruns:0 frame:0
TX packets:6446 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3821480 (3.8 MB) TX bytes:3821480 (3.8 MB)
Output for:
lspci -nn | grep 0280
02:00.0 Network controller [0280]: Broadcom Corporation BCM43228 802.11a/b/g/n [14e4:4359]
output for
cat /etc/network/interfaces
auto lo
iface lo inet loopback
How do I sort out this issue?
