What do I want to do?
Run this software in Ubuntu 12.04: Achieve Planner by Effexis (http://www.effexis.com/achieve/AchievePlanner19Download.htm).
What have I tried so far?
  • Installed PlayOnLinux through Software Center
  • (Tried to install .NET. Did not work b/c of 64bit. Did research, then moved on to the following steps.)
  • Installed Wine 1.7 and 1.6 (32bit) within PlayOnLinux using "Tools/Manage Wine Versions"
  • Installed .NET 1.1 (required by Achieve Planner) using the "Install" window's "Install a non-listed program" option.
  • Installed Achieve Planner the same way.
Where am I now?
Unable to launch Achieve Planner, and unable to interpret the error messages in the log file.
Background Info
  • Ubuntu 12.04 64bit
  • Acer Desktop M3640 | Intel® Core™2 Quad CPU Q6600 @ 2.40GHz x 4 | ATI Radeon HD 3650 | 3GB RAM
Joshua
It looks like there is a bug report for this on the WineHQ bug tracker. While wine can run many Windows Applications, it can not run everything yet. It may still be awhile until you can run Achieve Planner on linux. I recommend that you dual boot Windows or run Windows in a Virtual Machine until then.
tstew
  • 328
