I am looking to avoid ever typing in my email address again. Is there a way to configure a key to paste some pre-set bit of text like my email.
I'd like this to work across all applications ideally.
thanks
Braiam
  • 69,112
henryw374
  • 173
1) Install xclip and xdotool
sudo apt-get install xclip xdotool
2) Make a file myscript.sh
mkdir ~/bin
gedit ~/bin/myscript.sh
3) Copy paste this script into it
#!/bin/bash
TEXT="myname@address.com"
printf '%s' "$TEXT" | xclip -i -selection clipboard
xdotool key --clearmodifiers "ctrl+v"
4) Make the file executable
chmod +x ~/bin/myscript.sh
5) Make a shortcut
Settings -> Keyboard -> Shortcuts -> Custom shortcuts -> click [+]
  • Name: anything, Command: /home/USERNAME/bin/myscript.sh
    • Replace the USERNAME with your username
  • Click on the Disabled text and then press your magical keystroke. For example Ctrl-Shift-S
  • You may have to restart unity with setsid unity or by logging in and out to make the shortcut work. (at least i had this bug on Ubuntu 13.10)
Troubleshooting
If you have any problems with pasting the text. Try changing xdotool key to xdotool sleep 0.5 key. It gives you time to take your hands off the keyboard before xdotool tries to press "Ctrl-V"
squirl
  • 103
Niko Fohr
  • 1,571
  • 16
  • 27
The previous reply is from 2013 and we need something that works on 2021.
xdotool doesn't work on wayland.
xdotool does not always work as expected (i.e. it's sometimes very flaky).
An alternative tool to xdotool is ydotool.
1. install ydotool and xclip
sudo apt install -y ydotool xclip
2a. if you want to type text from the clipboard
Copy/paste is disabled on some applications and you may want to use this tool to type text instead of pasting.
Create a file ~/bin/myscript.sh
#!/bin/bash
xclip -o | ydotool type --delay 1000 --key-delay 70 --file -
2b. if you just want to type a text
This is easier.
#!/bin/bash
TEXT="ad eundem rivum lupus et agnus venerant" ydotool type --delay 1000 --key-delay 70 $TEXT
3. create a shortcut
maxadamo
  • 162
Try espanso which is a pretty good system-wide text expander:
https://espanso.org/
