I have installed Ubuntu 13.04 in Vmware workstation in my windows7 OS. I installed VMware tools in Ubuntu.
I have configured the shared folders in settings. Using the below command, I am able to get shared folders
/usr/bin/vmware-hgfsclient
But the shared folders are not present /mnt/hgfs
I tried to install Vmware tools multiple time but no luck.
Braiam
  • 69,112
Follow the steps. It worked for me for ubuntu 14.04 LTS running in vmware.
Make sure open-vm-tools is not installed. sudo apt-get remove open-vm-tools
  1. Make sure the updates are done: sudo apt-get update
  2. Make sure git is installed sudo apt-get install git
  3. Run the command to get the tools from repository. sudo git clone https://github.com/rasa/vmware-tools-patches.git
  4. cd to vmware-tools-folder cd vmware-tools-patches
  5. Run the patch sudo ./download-tools.sh
  6. Run the following patch sudo ./untar-and-patch.sh
  7. Run the complie.sh file sudo ./compile.sh
CKM
  • 161
A good and short solution for me was:
sudo vmware-config-tools.pl
You may be needed to logout&login afterwords.
Eli
  • 111
What problems did you have installing VMWare tools? I had a similar problem. After installing VMWare tools, I followed these instructions: How do I mount shared folders in Ubuntu using VMware tools?
Running the vmware-config-tools.pl ( sudo vmware-config-tools.pl ) again, then rebooting solved the problem. The files are in /mnt/hgfs/[shared folder name]
Mjj
  • 31
