I have an Hp Pavilion dv7 64bit system, 6gb memory, Ubuntu 12.10 partitioned with Win7,AMD Phenom(tm) II N640 Dual-Core Processor × 2 , 650g HDD.
This is what i'm getting through Terminal, same type of warning when going through software center. I've tried re-installing OS and it is MADDENING!
chris@ubuntu:~$ sudo apt-get install wine
[sudo] password for chris:
Reading package lists... Done
Building dependency tree
wine : Depends: wine1.4 but it is not going to be installed
The following is the warning from Software Center:
wine1.4: PreDepends: dpkg (>= 1.15.7.2~) but 1.16.7ubuntu6 is to be installed
Depends: libc6 (>= 2.14) but 2.15-0ubuntu20.1 is to be installed
Depends: wine1.4-amd64 (= 1.4.1-0ubuntu1) but 1.4.1-0ubuntu1 is to be installed
Depends: wine1.4-i386 (= 1.4.1-0ubuntu1) but it is not going to be installed
