I'm running Ubuntu 12.04 and tried to upgrade the kernel from 3.2 to 3.5: Following a suggestion found here, I ran
sudo apt-get install linux-image-generic-lts-quantal
I had a little trouble with it, but after reboot I have
uname -r
3.5.0-37-generic
However, attempting to install the new X stack results in an error:
sudo apt-get install xserver-xorg-lts-quantal
Reading package lists... Done
Building dependency tree
gvfs-daemons : Depends: x11-utils
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Any suggestions? I tried "sudo apt-get install gvfs-daemons" and "sudo apt-get install x11-utils", but both were up to date.
