I'm running Ubuntu 13.04, 64 bit, and I can't install wine. I've tried the solutions presented here and here, but to no avail.
When I use the command sudo apt-get install wine, the terminal returns
Reading package lists... Done
Building dependency tree
or been moved out of Incoming.`
wine : Depends: wine1.6 but it is not going to be installed
How can I install wine if these solutions do not work?
EDIT: It should be noted that I'm dual-booting Ubuntu 13.04 and Win7 EDIT: By following theseI was able to successfully install wine. Whether or not this is a result of all of the answers and these results, or just these results, I'm not sure.
Charles
  • 179
