79
I finally got RVM working and now I would like RVM to install the latest stable ruby version.
In the tutorial I am using they installed ruby 1.9.3 with command :
rvm install 1.9.3
Now I want to know if there is a command to download the latest stable version, or do I have to check latest stable version and download it like that, or else, can I download any old version and run an upgrade?
Normally I would try out everything, but I am working on a new server and I am trying to set it up as clean as I can :)
Private
  • 4,074
The following command will install latest stable version of ruby:
rvm install ruby --latest
Eliah Kagan
  • 119,640
user311140
  • 1,051
80
you can install latest rvm and ruby by :
$ \curl -L https://get.rvm.io | bash -s stable --ruby
and check all the ruby version with stability
$ rvm list known
can also check details here : http://www.ruby-lang.org/en/downloads/
$ rvm install ruby 2.0.0-p247
Use when you want to download specific version or know this is stable.
echo rvm_autoupdate_flag=2 >> ~/.rvmrc
Bruno
  • 173
This command will help you to install latest stable version of Ruby using RVM.
rvm get stable
To install the latest stable Ruby version you need to run:
This command will install the latest stable version of Ruby after updating RVM.
karel
  • 122,292
  • 133
  • 301
  • 332
