I don't like the default functionality of the mouse's scroll wheel click doing a "paste". I can change that by doing the follwing:
$ xinput set-button-map 12 1 0 3 4 5 6 7
This works fine, but if I reboot, I have to remember to do it again.
My question is how can I make this happen automatically if I need to reboot, etc?
I'm using Ubuntu 12.04
Braiam
  • 69,112
David S
  • 181
You have to add that line in your .xsessionrc file. To do this, use the following command:
echo "xinput set-button-map 12 1 0 3 4 5 6 7" >> ~/.xsessionrc
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
You can either run the command at every login or you can put it in the X.org configuration (/etc/X11/xorg.conf) like this:
Section "InputDevice"
    Identifier     "Logitech USB-PS/2 Optical Mouse"
    Driver         "evdev"
    Option         "Device" "/dev/input/by-id/usb-Logitech_USB-PS_2_Optical_Mouse-event-mouse"
    Option         "ButtonMapping" "12 1 0 3 4 5 6 7"
EndSection
I don't know the identifiers and driver options of your device, but you get those with xinput and by sniffing around in /dev/input.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
If you use startx or init 3, the xessionrc is a good solution
echo "xinput..yourcommand" >> $HOME/.xsessionrc
If you use xfce on init 4/5 a good solution is to create a .destkop file which point to a script, in which you type the commands.
For example
vim  .config/autostart/xinput.desktop
    [Desktop Entry]
    Hidden=false
    Version=1.0
    Name=xinput
    Name[no]=xinput
    Name[pt_BR]=xinput
    Name[ru]=xinput
    Name[sl]=xinput
    Name[sv]=xinput
    Comment=xinput
    Comment[no]=xinput
    Icon=xinput
    Terminal=false
    Type=Application
    StartupNotify=false
    Categories=System;
    Exec=/home/you/scripts/xinput.sh
    RunHook=0
vim /home/you/scripts/xinput.sh
#!/bin/bash
xinput..yourcommand
Make it executable
chmod +x /home/you/scripts/xinput.sh
At the next login the command will run.
elbarna
  • 224
