73
I'm trying to restart Apache 2:
sudo service apache2 restart
But get the below error:
* Restarting web server apache2
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1.
Set the 'ServerName' directive globally to suppress this message
I've tried to change
sudo gedit /etc/apache2/httpd.conf
A blank file appears, and I'd added this:
ServerName localhost
But that error doesn't disappear!
How can I fix this problem?
muru
  • 207,228
I found this: How do I restart/reload Apache when it can't determine the domain name?
Good news! Apache is restarting successfully. Apache just isn't sure where you want serve from, so it's choosing your localhost (127.0.0.1) by default. To prevent this message from appearing, clarify that you want to serve from localhost (127.0.0.1) by adding the following line into your /etc/apache2/apache2.conf file:
Meintjes
  • 2,450
35
Specifying ServerName localhost in your configuration files outside of the virtual host sections is the way to do this.
Other answers suggest that you should modify /etc/apache2/httpd.conf. This file gets overwritten when apache gets upgraded from apt. For Apache configuration that you don't want to get overwritten, you should create a new file. Here is the "Debian way" to make this configuration change:
# create the configuration file in the "available" section
echo "ServerName localhost" | sudo tee /etc/apache2/conf-available/servername.conf
# enable it by creating a symlink to it from the "enabled" section
sudo a2enconf servername
# restart the server
Your localhost IP Address should be 127.0.0.1, instead of 127.0.1.1. Please setup your /etc/hosts file properly. Then edit the httpd.conf file:
sudo -H gedit /etc/apache2/httpd.conf
When a blank file appears, please add this line, then save:
Zanna
  • 72,312
Masabza
  • 51
Here is another Solution:
Before:
[root@centos ~]# /etc/init.d/httpd restart
Stopping httpd:                                            [  OK  ]
Starting httpd: httpd: apr_sockaddr_info_get() failed for centos.wks.local
httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
                                                           [  OK  ]
Added 192.168.226.131 centos.wks.local in /etc/hosts file
Note: 192.168.226.131 is my Apache server IP address.
After:
Starting httpd:                                            [  OK  ]
Rahul Patil
  • 324
