Trying to use the Radeon 8790M on my Dell Latitude E6540 running Kubuntu 13.04 (Raring). This laptop also has an Intel adapter (for power saving). lspci gives:
$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Haswell Integrated Graphics Controller (rev 06)
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Mars [Radeon HD 8790M]
Tried using the standard fglrx and fglrx-update and aticonfig results in (in a message box):
aticonfig: No supported adapters detected
Trying AMD's drivers always renders the same result:
Your graphics adaper is not supported by this driver. Installation will not proceed.
There is no 3D acceleration, as evident by running glxgears:
$ glxgears
X Error of failed request:  BadRequest (invalid request code or no such operation)
Major opcode of failed request:  153 (GLX)
Minor opcode of failed request:  19 (X_GLXQueryServerString)
Serial number of failed request:  12
Current serial number in output stream:  12
This may be an issue of the multi-adapter situation, but I'm not sure how to resolve this.
stanga
  • 141
Indeed patience was the solution.
ATI just published an updated driver (13.8 beta2), which installs successfully.
stanga
  • 141
I suppose you have installed AMD Catalystâ„¢ 13.4 Proprietary Linux Graphics Driver. Read the Release Notes for Catalystâ„¢ 13.4. It does not support the AMD Radeon 8000 series. May be you should try installing AMD Catalystâ„¢ 13.8 LINUX Beta Driver. It supports 8000 series according to the link. Warning: 13.8 is still in beta stage.
Yash
  • 136
