I want to develop web applications with PHP, for that reason I need to install a LAMP system, I heard that it's good idea to use latest versions of PHP, MySQL and Apache ... so if it's possible please help me ...
You can install lamp server by just running,
sudo apt-get install lamp-server^
(Please see this answer for an explanation.)
Then you can copy your files into /var/www folder and view through browser in localhost. Since copying files into /var/www folder needs privileges and annoying you can change that directory to your own one.
you can replace "/var/www" string in following files into your own directory path and then you can use new directory as your www folder.
/etc/apache2/sites-available/default
/etc/apache2/sites-available/default-ssl
After changing contents of the above files, run
sudo /etc/init.d/apache2 restart
to restart webserver. Then you will be able to use new directory as the web folder.
Hope this helps.
Start by installing tasksel, then install the lamp-server. As per the Ubuntu help documentation.
sudo apt-get install taskselsudo tasksel install lamp-server
And you are off. Just place your files in /var/www/
go to localhost in a browser and view your files.
- 17,038
