10
I am using a script to automatically set up a computer. I need to assign a password to the vnc server for the user, which is normally done using the vncserver command. However, it prompts for the user to enter and re-enter their password, neither of which the script is capable of doing. So, how can I set up the VNC password without an interactive prompt?
Thanks.
William
  • 7,720
5 Answers5
13
Was able to do it this way today (from a dockerfile at least):
RUN printf "password\npassword\n\n" | vncpasswd
ibic
  • 103
coding
  • 231
13
I found another way of doing this in a script (as root):
#!/bin/sh
myuser="asimov"
mypasswd="mysecret"
mkdir /home/$myuser/.vnc
echo $mypasswd | vncpasswd -f > /home/$myuser/.vnc/passwd
chown -R $myuser:$myuser /home/$myuser/.vnc
chmod 0600 /home/$myuser/.vnc/passwd
Cheers!
Dawied
  • 231
As far as I know, the vncserver command only prompts for a password if the password file (by default, $HOME/.vnc/passwd) is absent - typically the first time it's run for a particular user. You could either script that initial vncserver interaction using 'expect', or pre-create the user's password file by calling the vncpasswd utility via expect before you run vncserver for the first time; e.g. [CAUTION: this is absolutely minimal, you should add some sanity checks if this is used in a serious environment]
#!/bin/sh
prog=/usr/bin/vncpasswd
mypass="newpass"
/usr/bin/expect <<EOF
spawn "$prog"
expect "Password:"
send "$mypass\r"
expect "Verify:"
send "$mypass\r"
expect eof
exit
EOF
If you don't want to (or can't) use 'expect', then there are various hacks available on the web - VNC passwords apparently use a form of DES encryption so searching with the terms 'VNC' 'DES' 'password' should get you what you need (I'm not going to link here since I cannot vouch for any particular one).
For completeness, note that the default Ubuntu 'Desktop Sharing' uses vino, and the password for that appears to be simply base64 encoded, so it is possible to set it directly e.g.
gsettings set org.gnome.Vino vnc-password "$(echo -n "newpass" | base64)"
Hope this helps
steeldriver
  • 142,475
By slightly modifying steeldriver's version I was able to automate my usage of vncpasswd. Allows passing both the password and filename for vncpasswd to create.
Usage: $ ./scriptname <filename> <password>
#!/bin/sh
myuser="$1"
mypass="$2"
spawn /usr/bin/vncpasswd $myuser
expect "Password:"
send "$mypass\r"
expect "Verify:"
send "$mypass\r"
expect eof
exit
EOF
Mike J
  • 121
In Ansible (requires pexpect to be installed on target):
    - name: Set vnc password for tigervnc
      expect:
        command: vncpasswd /home/{{ UserName }}/.vnc/passwd
        responses:
          (?i)password: "max8char"
          (?i)verify: "max8char"
          (?i)\(y/n\): "n"
Jean Monet
  • 273
