Attempting to boot from a 16GB SDHC card on an HP ProBook 4530s. Used universal USB installer (pendrive) supplied via link from ubuntu.com to create the bootable drive. In the start up menu, I choose the SD card as the boot device, it starts, shows some script, shows the Ubuntu installing screen for a lengthy while, back to script then "Unable to find medium containing live file stream"
Comp is currently running Win7 prof 64bit Trying to load ubuntu 13.04 amd64.
Not sure if this matters, but it cant hurt: i5 quad core 2.3ghz 8GB ddr3 intel HD graphics
user300458
  • 2,138
Matt
I am assuming the boot-able image created is faulty.
Format your SD card : Your windows might not format the SD card properly. Use the software from SD SD Formatter 4.0 for Windows Download
Download a fresh copy of the Ubuntu .iso and then use below tool for windows to create a bootable card using Win32 Disk Imager.
Should work after this. :)
Dexobox
  • 121
