I am trying to install hadoop on Ubuntu 12.04. I followed the following article.
http://www.michael-noll.com/tutorials/running-hadoop-on-ubuntu-linux-single-node-cluster/
I have installed hadoop as per the instruction given in this tutorial. I have installed hadoop-0.23.9.tar.gz, though the site mentions an older version. It also mentions about updating hadoop-env.sh file. I could not find this file under /usr/local/hadoop/conf. There is no directory 'conf' under hadoop directory. It could be that this file is located somewhere else due to version change, but I am unable to find it. I want to know where this configuration file is located under the main hadoop directory.
KurioZ7
  • 201
Run following command on terminal to find it :
find hadoop/ -name hadoop-env.sh
Replace hadoop/ with your hadoop folder name
Anil Arya
  • 151
The usual location for the configuration and environment is in /etc/hadoop. Example: hadoop-2.5.1//etc/hadoop/hadoop-env.sh
muru
  • 207,228
For the most recent hadoop release, the file hadoop-env.sh can be found in:
/usr/local/hadoop/hadoop-common-project/hadoop-common/src/main/conf
pd441
  • 111
You may search in this folder for hadoop_env.sh /usr/local/hadoop{your_hadoop_folder_name}/hadoop-common-project/hadoop-common/src/main/conf/
