Reading package lists... Error!
E: Write error - write (9: Bad file descriptor)
E: The package lists or status file could not be parsed or opened.
david@david-Inspiron-N5110:~$
Asked
Active
Viewed 605 times
welcome to askUbuntu ;)
open up your terminal (ctrl+alt+t) or you can find it using the superkey (the windowskey in windows) and then write terminal. In terminal first write:
sudo rm /var/lib/apt/lists/* -vf
then hit enter. a password prompt will be showed up, enter password and hit enter. Afterward run the update manager in terminal via:
sudo apt-get update && sudo apt-get upgrade
and hit enter. wait for the packages to be upgraded and updated.
EDITED/Added: Thanks to @Alexis Wilke : First check the /var partition of your hard whether its full or not. Do it using terminal with the command :
df -h
if so, clean up some space and the retry ;)
Hope that works ;)
Amir
- 1,111
