I used chrubuntu to install Xubuntu on a new Acer C7 chromebook. One thing that's not working correctly is use of the up-arrow key in the terminal...rather than recall the last command it writes: ^[[A
Anyone know why this is and/or how to fix it?
The terminal is running sh instead of bash which you are used to. Type bash and you will get what you are looking for. To make this permanent when you open up a terminal change your default shell in /etc/passwd.
First, you can try to start a bash shell once, to figure out if the problem is your shell. Type
bashin the terminal. If arrow up history now works, you can set bash as your default shell by running the
chshcommand. This command will prompt you for your password, and then what shell you want to use, for example
/bin/bash.
If this does not work, you can try another terminal program. One example is the Gnome Terminal, which is available in the Ubuntu Software Center.
