How can I create a dedicated hard drive to do "swap"on a ubuntu 12.04 LTS?
You don't have to use a partition or hdd for swap.
Just create a swap file using dd or fallocate.
Create a file of filled with zeros 1GB in this case:
 dd if=/dev/zero of=/mnt/swap.img bs=1M count=1024
Preferred method: use fallocate instead of dd
NOTE: fallocate is much faster than dd because it quickly allocates blocks and mark them as uninitialized, no I/O to the blocks.
fallocate -l 1024M /mnt/swap.img
Format the file to create a swap device
mkswap /mnt/swap.img
Adding the swap to the running system:
swapon /mnt/swap.img
Make it permanent, edit /etc/fstab and add the following entry:
/mnt/swap.img  none  swap  sw  0 0
More information: https://help.ubuntu.com/community/SwapFaq
Terry Wang
  • 10,185
