Skype is not installing in my Ubuntu.
sudo apt-get install skype
giving following output.
Reading package lists... Done
Building dependency tree
 skype : Depends: ia32-libs (>= 20080808) but it is not going to be installed
W: Duplicate sources.list entry http://archive.canonical.com/ubuntu/ maverick/partner amd64 Packages (/var/lib/apt/lists/archive.canonical.com_ubuntu_dists_maverick_partner_binary-amd64_Packages)
W: You may want to run apt-get update to correct these problems
please help
Tim
  • 33,500
Run
sudo apt-get update
and than again :
Private
  • 4,074
It seems, that you are trying to install a 32-bit package on a 64-bit machine. ia32-libs make it possibe to install 32-bit on 64-bit. Type "ia32" in Softwarecenter and install packages. Afterwards try again to install Skype. Or try to reinstall ia32-libs, if you have them already installed. Or download 64-bit package, if it is available.
