I just downgraded from 13.04, which seems to have some stability problems right now, and moved back to 12.04.LTS.
I installed the GCC 4.8 compiler, which is not the default GCC compiler on 12.04. I need this compiler to get all the C++ 11 features it supports and were there by default with the compiler that comes with 13.04, using the ‘-std=c++11' switch.
So now I have 4.8 compiler installed, but I can't figure out how to make applications understand that the new compiler should be used for gcc/g++ instead of the default GCC compiler that comes with 12.04 (4.4.x?). How do I do this?
I saw somewhere that update-alternatives would do it. But I don't know to how use it to set the new GCC compiler to be the system default.
