I have got Win 8 on my SSD and I want to install Ubuntu on my HDD. Can I? Thanks. My SSD is 120 GB and when I try to access it gives this error in "trying Ubuntu" :
Error mounting /dev/sda2 at /media/ubuntu/2284BD1E84BCF57F: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999,dmask=0077,fmask=0177" "/dev/sda2" "/media/ubuntu/2284BD1E84BCF57F"' exited with non-zero exit status 14: Windows is hibernated, refused to mount.
Failed to mount '/dev/sda2': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
Thanks for advance.
Mitch
  • 109,787
The answer is in the question.
You have to shutdown Windows, not just hybernate it.
I think that on windows 8 (at least on some versions) this is an hidden option not showing up in the standard menus.
dadexix86
  • 6,776
This is caused by the fact that Windows 8 doesn't shut down, but only hibernates. This means the Windows file system is still dirty after you switch off your computer. If you configure Windows 8 to shut down properly, then this problem will go away.
-1
Some links to more instructions. Fast Startup off/hibernation
http://www.eightforums.com/tutorials/6320-fast-startup-turn-off-windows-8-a.html
Force removal of hiberfil from Ubuntu
http://www.hecticgeek.com/2013/01/mount-windows-8-partition-ubuntu-hybrid-boot/
oldfred
  • 12,583
