I am going to download & install java on Ubuntu 12.04 LTS (32-bit system)
On java download page, there are 2 download options.
- Java for Linux Platforms
- Java for RPM based Linux Platforms
Which would be better suited for Ubuntu?
RPM is Redhat, Fedore, CentOS so unusable.
You need, preferably, a DEB version or otherwise the tar.gz version.
I would advicw to use a personal archive as explained here:http://www.webupd8.org/2012/06/how-to-install-oracle-java-7-in-debian.html
Install method for java 7:
su -
echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu precise main" | tee -a /etc/apt/sources.list
echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu precise main" | tee -a /etc/apt/sources.list
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys EEA14886
apt-get update
apt-get install oracle-java7-installer
exit
You can then install this...
sudo apt-get install oracle-java7-set-default
"To automatically set up the Java 7 environment variables"
Use the Java for Linux Platforms. Here are the download instructions There is a similar question on how to install JDK 7
Download the 32bit or 64bit Linux "compressed binary file" - it has a ".tar.gz" file extension and uncompress it
tar -xvf jre-7-linux-i586.tar.gz
JRE 7 package is extracted into ./jre1.7.0 directory. Now move the JRE 7 directory to /usr/lib
sudo mv ./jre1.7.0* /usr/lib/jvm/jre1.7.0
Afterwards run the following to get a list of currently installed java alternatives
sudo update-alternatives --config java
You will get output as:
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/java-6-openjdk/jre/bin/java 1061 auto mode
1 /usr/lib/jvm/java-6-openjdk/jre/bin/java 1061 manual mode
2 /usr/lib/jvm/java-6-sun/jre/bin/java 63 manual mode
Press enter to keep the current choice[*], or type selection number:
Remember the last number and press enter to exit this utility i.e. in this example remember the number 2.
If only one alternative is shown then remember the number 0
sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jre1.7.0/bin/java 3
This will add your new JRE 7 installation into alternatives list i.e. use the remembered number + 1 i.e. 3 in the example above. Now configure java to use the Oracle Java JRE
You will see output similar one below - choose the number of jre1.7.0 i.e. 3:
There are 3 choices for the alternative java (providing /usr/bin/java).
3 /usr/lib/jvm/jre1.7.0/jre/bin/java 3 manual mode
Press enter to keep the current choice[*], or type selection number: 3
update-alternatives: using /usr/lib/jvm/jre1.7.0/jre/bin/java to provide /usr/bin/java (java) in manual mode.
N.B. if there was no previous java installation then the new JRE will be the default and you will not see the above.
Check the version of you new JRE 7 installation:
java -version
Should produce
java version “1.7.0”
Java(TM) SE Runtime Environment (build 1.7.0-b147)
Java HotSpot(TM) Client VM (build 21.0-b17, mixed mode)
In a terminal:
mkdir ~/.mozilla/plugins
Remove the IcedTea plugin, if it has been installed.
sudo apt-get remove icedtea6-plugin
Remove a former version of the Java plugin (may or may not be present)
rm ~/.mozilla/plugins/libnpjp2.so
Now you can install the plugin, by creating a symbolic link (you tell Firefox, where the plugin is located). For 32bit java use
ln -s /usr/lib/jvm/jre1.7.0/lib/i386/libnpjp2.so ~/.mozilla/plugins/
For 64bit java use
ln -s /usr/lib/jvm/jre1.7.0/lib/amd64/libnpjp2.so ~/.mozilla/plugins/
Confirm that the JRE has been successful by using the official oracle website.
SOURCE: How can I install Sun/Oracle's proprietary Java JDK 6/7/8 or JRE?
