23
I'm attempting to block myself from time-wasting websites but changes I make to /etc/hosts. For example:
127.0.0.1   localhost
127.0.1.1   ross-laptop
127.0.0.1   bing.com
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
I can access bing.com in a freshly opened Chrome or Firefox - why is this not working?
Seth
  • 59,332
Ross
  • 1,832
5 Answers5
19
You'll find the browsers and the system will cache things for you. In order to get this to apply right off the bat you should make sure to clear caches and restart your browser. In order to test this out, try performing a dns check from a terminal such as
ping bing.com
You should get it replying back from 127.0.0.1. If this works then your hosts file change is good, but it's just cached in your browser.
Rick
  • 3,727
Have you tried putting the 127.0.0.1 entries on the same line?
120.0.0.1 abc bing.com foo
That should work.
Marco Ceppi
  • 48,827
Open Terminal (ALT+F2).
Type sudo -i in the input field. Check the Run in terminal option. Finally click Run button.
Type your password if necessary and press enter. Then enter the following commands.
gedit /etc/hosts
You will get Gedit Text Editor window.
For Example, if we need to block Facebook add the following lines just after 127.0.0.1 localhost.
0.0.0.1 facebook.com
0.0.0.1 www.facebook.com
By doing this, it will block the site in all browsers including Google Chrome, Chromium, Mozilla.
That's it. When you now open www.facebook.com or facebook.com, you cannot access it. To enable back Facebook, remove the lines we added from the file /etc/hosts.
Source - Subin's Blog
Subin
  • 760
  • 16
  • 32
-1
Besides CragM's solution, remember you can use all 127.x.x.x address for this purpose, don't repeat the same address.
127.0.0.1   localhost
127.0.0.2   ross-laptop
127.0.0.3   bing.com
127.0.0.4   foo.com
127.0.0.5   bar.com
grokus
  • 631
-1
Modifying /etc/hosts looks like a global hack. I'd suggest setting up a local http proxy instead (squid, privoxy etc) and point your browser to use it. This way you would get a more flexible way of managing blacklists at proxy level.
vh1
  • 1,473
