My machine is running Ubuntu 12.10 with Gnome 3.6; I have 2GB of RAM and I have allocated 1 GB of swap space during installation. And I am not running out of it anytime (as I'm aware/think so), acording to my swap memory applet the average is around 10-15%. But I am still a way less that recommended, as here explained. Could I be facing any potential problem about it?
  • If so, what? And should I increase my Swap space anyway?
P.S.
I have read about the Importance of Swap Partition.
Also about How to increase SWAP space in Ubuntu? and more...
But I couldn't find the answer I am looking for.
The only problem I can see is that if you were to edit a huge photograph or play a memory hungry game, there may be a lot of disk activity.
If that would be a problem for you, you can easily adjust the swap file in gparted available from the Software Centre.
Simon
  • 4,843
No.
If so, what?
Unless you like to keep hundreds of tabs with lots of images and try to open several GiB files with GIMP you are OK.
In this case apply the rule if it's not broken, why fix it?. You only should increase your swap partition when you are getting OOM's, otherwise an excessive big swap will be most of the time unnecessary.
Braiam
  • 69,112
