I installed Ubuntu 13.04. Then I installed too KDE Plasma Environment. Then I removed KDE. Everything went fine. I can now log with Ubuntu (Unity).
Only (small) remaining problem: on the boot page (Grub), the command line does not show "Ubuntu 13.04" but "Kubuntu 13.04". Is there a way to fix this little inconvenience? Thanks in advance.
Default value of variable GRUB_DISTRIBUTOR is set to
lsb_release -i -s 2> /dev/null || echo Debian by /etc/default/grub script while generating grub.cfg.
Check your /etc/default/grub.d/ directory for scripts which could overwrite this variable.
In my case it was /etc/default/grub.d/50_kubuntu.cfg which has been created by KDE Plasma Environment so I deleted it and generated grub.cfg again.
To solve this problem, simply type into terminal:
sudo rm /etc/default/grub.d/50_kubuntu.cfg
sudo update-grub
Just run in a terminal the following command:
sudo update-grub
If still the problem persist, run:
sudo sed -i 's/Kubuntu/Ubuntu/g' /boot/grub/grub.cfg
You can also see:
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
The problem might be the kernel and initrd images (vmlinuz-* , initrd.img-* ). Try reinstalling your kernels and it might fix the problem.
BuZZ-dEE
  • 14,533
