14
I'm trying to install Java SE 7 on my ubuntu 13.04.
I have already downloaded tar.gz file and extracted.
But when I wrote in terminal:
./configure
I saw this message
bash: ./configure: No such file or directory
I see it even after installing build essentials package.
Any idea?
Danatela
  • 13,384
stackylnr
  • 141
You only run the ./configure command when building certain applications from source.
The Java installation files that you have downloaded aren't source code they are precompiled binaries. For instructions on how to install Java take a look at the page on the Ubuntu Wiki as this has several different options.
I recomend using the option titled 'Using webupd8.org's strikingly simple method.' as it will integrate the installation of Java with your package manaement system and automatically keep it up to date along with the rerst of your system.
Cheesemill
  • 1,007
Preamble
The reason why you are getting the "bash: ./configure: No such file or directory" is because you are not in the right directory where the downloaded file you are about to install is located.
To fix that
(a.) FOLLOWING README INSTRUCTION
  1. Locate where your downloaded Java tar.gz file.
  2. Extract the file by right-clicking on it and select 'Extract Here'.
  3. Look for the 'Readme text' file and open it.
  4. Follow the instruction on how to install the file in the Readme text(installation of tar.gz file can be different from normal commands used to do installation of files in Ubuntu).
(b.) USING GENERAL COMMANDS
  1. Open the terminal by pressing CTRL + ALT +T.
  2. Type tar -zxvf .tar.gz .
  3. Type sudo su and enter your root password.
  4. type cd and add the path of your downloaded file . If you do not know the path of the downloaded file type ls -a to list all the directories and locate your file directory.
  5. Type ./configure and press ENTER key
  6. Type make and press ENTER key.
  7. Type make install and press ENTER key.
(c) USING THE UBUNTU SOFTWARE CENTER
  1. Open Ubuntu Software Center
  2. Type java in the search
  3. Look for Java SE 7 and click 'install' to install it.
all4naija
  • 1,554
I also had this problem. The short answer is you have to type ./configure --prefix=/your/chosen/directory when inside the unpacked .tar.gz file directory. That is where the configure file is.
Astrophe
  • 107
Mark
This happened with me while installing samba domain controller and You may downloaded the package like me as below: (The commands are related to samba installation!!)
git clone -b v4-5-stable git://git.samba.org/samba.git
and you are in folder say (ex: folder1) and when you type
(ex: ./configure --enable-debug --enable-selftest)
it bring up an error
So here I had to go inside the samba folder in the folder1
/home/ubuntu/folder1/samba# I know it is very late answer but this may help :)
