I recently bought an Asus Zenbook UX32A. Now I'm trying to dualboot it with XP and Ubuntu 13.04.
Both OS's seem to have installed correctly but I just can't boot into grub to let me choose wich OS I want to use. By default XP loads.
I've created separate partitions on my SSD and HDD.
I would like to share the ssd for both OS's but keep all the documents and stuff on the hdd, so I mounted /var and /home to the hdd. / is on the SSD
this is my fdisk output:
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted. Disk /dev/sda: 500.1 GB, 500107862016 bytes 255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0xc61722b1 Device Boot Start End Blocks Id System /dev/sda2 2046 169228287 84613121 5 Extended Partition 2 does not start on physical sector boundary. /dev/sda4 * 169228288 322826239 76798976 7 HPFS/NTFS/exFAT /dev/sda5 2048 7812594 3905273+ 83 Linux /dev/sda6 7815168 15626239 3905536 82 Linux swap / Solaris /dev/sda7 15628288 169228287 76800000 83 Linux WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted. Disk /dev/sdb: 32.0 GB, 32017047552 bytes 255 heads, 63 sectors/track, 3892 cylinders, total 62533296 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xfed1007e Device Boot Start End Blocks Id System /dev/sdb1 2048 30722047 15360000 83 Linux /dev/sdb2 * 30722048 62529535 15903744 7 HPFS/NTFS/exFAT Disk /dev/sdc: 8095 MB, 8095006720 bytes 255 heads, 63 sectors/track, 984 cylinders, total 15810560 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xefacefac
Here is my Boot Repair log
Might the failure to load GRUB 2 be linked to some EFI-thing? All help will be truly appreciated, I'm actually stuck!
