I have follow the instructions listed in the forum as well as the thinkorswim website. I can get all the way to the launch point for showing the desktop and it won't show I just get a black screen and it freezes on showing desktop. I think it has to do with one either the java I am running or so have said I need to get the thinkorswim tech support to disable the splash start up screen.
I had a similar problem under Fedora and Gnome Shell. The main Thinkorswim window didn't show up, and looking at top, Java and Xorg used up all CPU.
I managed to properly run Thinkorswim after switching to Openbox as a window manager. My guess is that any non-compositing window manager will do.
- 1
Having a similar issue, I approached the thinkorswim tech support and received these instructions which worked for me: Linux java 7 and tos install instructions
Before installing think or swim you will need to install Oracle Java 7. One way to install it by adding the Webd8 PPA.
http://www.webupd8.org/2012/01/install-oracle-java-jdk-7-in-ubuntu-via.html
First:
First Install WEBUPD8
sudo add-apt-repository ppa:webupd8team/javaRun the next command
sudo apt-get updateRun this command to install java
sudo apt-get install oracle-java7-installer
Download Think or Swim
You will need to download think or swim Linux version from the link below.
You will need to download the thinkorswim_installer.sh and save it to your downloads folder.
Open the Terminal and Change to the Download Directory using the cd command
To run think or swim installer type the following command sh thinkorswim_installer.sh
- 1
