19
I want to run a command that requires the sudo password say:
sudo apt-get update
Isn't this supposed to work (I have stored the password in a normal text file passwd.txt):
sudo apt-get update <~/passwd.txt
This is my logic for for why it SHOULD work: when the password is required, the user is asked to input the password from the keyboard. But redirecting the stdin to read from the passwd.txt file should work.
Shouldn't it?
Eric Carvalho
  • 55,453
MichaelB
  • 335
sudo doesn't read password from stdin by default. From sudo manpage:
-S  The -S (stdin) option causes sudo to read the password from the standard input instead of the terminal device.
    The password must be followed by a newline character.
So you should run:
sudo -S apt-get update <~/passwd.txt
Keep in mind that storing passwords in files is not a good practice. You should read:
Eric Carvalho
  • 55,453
