12
In my case the software I am trying to convert is the Lacie lightscribe labeler.
1.- I renamed the RPM
mv LaCie\ LightScribe\ Labeler\ 1.0\ Linux.rpm lacie-lightscribe-labeler-1.0.rpm
2.- Convert the package with alien
sudo alien lacie-lightscribe-labeler-1.0.rpm
Error:
lacie-lightscribe-labeler-1.0.rpm is for architecture i386 ; the package cannot be built on this system
I know that:
  • I could do this in a x86 system and then copy it from there.
  • Use the simple labeler
I'm curious about how to do this conversion in general.
givanse
  • 601
The process is quite easy, in short you need to modify the control file and that's it.
sudo alien -g package-name.rpm
cd package-dir/
sudo vi debian/control
Now change the architecture (i386 in my case) to be the one you need. For example, I added the amd64 architecture and this is how the line ended up:
Architecture: i386, amd64
Last step:
sudo debian/rules binary
This will produce the .deb file.
References:
givanse
  • 601
10
I made it work with just this command:
fakeroot alien --target=amd64 package.i586.rpm
Eric Carvalho
  • 55,453
Doeners
  • 101
This should be an easy work-around as well, as found on https://www.maketecheasier.com/convert-32bit-rpm-to-deb-64bit/ - use TGZ as an intermediate stage:
sudo alien --scripts --to-tgz <package.rpm>
sudo alien --scripts --to-deb <package.tgz>
The --to-deb is a default, used here only to be explicit about the conversions.
Then, install with dpkg as usual (when using a raw .deb from Alien).
Randall
  • 356
