I recently purchased a Lenovo g505s, the specifications of which can be found here.
After setting up Ubuntu 13.04 I tried to install the ATI proprietary drivers. But only my integrated graphics are being detected. Plus there’s an AMD unsupported hardware water mark at the bottom right of my screen(not an issue as long as the system works).
Even lspci -v command does not detect my dedicated graphic card. I tried to check my BIOS but I can't find any option to switch between integrated and dedicated graphics. Currently the graphics option under BIOS is set to switch-able graphics.
Please help me enable my dedicated graphic card. Here is the output of lspci -v :-
dexter@dexter-Lenovo-G505s:~$ lspci -v
00:00.0 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Complex
Subsystem: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Complex
Flags: bus master, 66MHz, medium devsel, latency 32
00:01.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Richland [Radeon HD 8650G] (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 3804
Flags: bus master, fast devsel, latency 0, IRQ 52
Memory at e0000000 (32-bit, prefetchable) [size=256M]
I/O ports at 3000 [size=256]
Memory at f0200000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
Kernel driver in use: fglrx_pci
00:01.1 Audio device: Advanced Micro Devices [AMD] nee ATI Trinity HDMI Audio Controller
Subsystem: Lenovo Device 397c
Flags: bus master, fast devsel, latency 0, IRQ 46
Memory at f0244000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:04.0 PCI bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Port (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f0100000-f01fffff
Kernel driver in use: pcieport
00:05.0 PCI bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Port (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: f0000000-f00fffff
Prefetchable memory behind bridge: 00000000f0300000-00000000f03fffff
00:10.0 USB controller: Advanced Micro Devices [AMD] FCH USB XHCI Controller (rev 09) (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at f0248000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: xhci_hcd
00:11.0 SATA controller: Advanced Micro Devices [AMD] FCH SATA Controller [AHCI mode] (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 45
I/O ports at 3118 [size=8]
I/O ports at 3124 [size=4]
I/O ports at 3110 [size=8]
I/O ports at 3120 [size=4]
I/O ports at 3100 [size=16]
Memory at f024e000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:12.0 USB controller: Advanced Micro Devices [AMD] FCH USB OHCI Controller (rev 11) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 18
Memory at f024d000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:12.2 USB controller: Advanced Micro Devices [AMD] FCH USB EHCI Controller (rev 11) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 17
Memory at f024c000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: ehci-pci
00:13.0 USB controller: Advanced Micro Devices [AMD] FCH USB OHCI Controller (rev 11) (prog-if 10 [OHCI])
Memory at f024b000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB controller: Advanced Micro Devices [AMD] FCH USB EHCI Controller (rev 11) (prog-if 20 [EHCI])
Memory at f024a000 (32-bit, non-prefetchable) [size=256]
00:14.0 SMBus: Advanced Micro Devices [AMD] FCH SMBus Controller (rev 16)
Flags: 66MHz, medium devsel
00:14.2 Audio device: Advanced Micro Devices [AMD] FCH Azalia Controller (rev 01)
Flags: bus master, slow devsel, latency 32, IRQ 16
Memory at f0240000 (64-bit, non-prefetchable) [size=16K]
00:14.3 ISA bridge: Advanced Micro Devices [AMD] FCH LPC Bridge (rev 11)
Flags: bus master, 66MHz, medium devsel, latency 0
00:14.4 PCI bridge: Advanced Micro Devices [AMD] FCH PCI Bridge (rev 40) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=64
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 0
Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 1
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 2
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 3
Flags: fast devsel
Kernel driver in use: k10temp
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 4
Flags: fast devsel
00:18.5 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 5
Flags: fast devsel
01:00.0 Ethernet controller: Qualcomm Atheros QCA8172 Fast Ethernet (rev 10)
Subsystem: Lenovo Device 3806
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f0100000 (64-bit, non-prefetchable) [size=256K]
I/O ports at 2000 [size=128]
Kernel driver in use: alx
02:00.0 Network controller: Atheros Communications Inc. AR9485 Wireless Network Adapter (rev 01)
Subsystem: Lenovo Device 3218
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f0000000 (64-bit, non-prefetchable) [size=512K]
Expansion ROM at f0300000 [disabled] [size=64K]
Kernel driver in use: ath9k
