I have just bought a new laptop. Acer v7-582PG. Everything works great with Ubuntu, exept the wireless module. I have tried Ubuntu 13.04 and 13.10 Beta. Still no luck.
It is kind of a new wireless card, so there is very little information out about it.
lspci: 04:00.0 Network controller: Intel Corporation Wireless 7260 (rev 63)
sudo lshw -c network
ubuntu@ubuntu:~$ sudo lshw -c network
  *-network UNCLAIMED
       description: Network controller
       product: Wireless 7260
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:04:00.0
       version: 63
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:b3500000-b3501fff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0.1
       bus info: pci@0000:05:00.1
       logical name: eth0
       version: 14
       serial: 08:9e:01:c3:24:50
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=10.0.0.106 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
       resources: irq:62 ioport:4000(size=256) memory:b3404000-b3404fff memory:b3400000-b3403fff
rfkill list all
ubuntu@ubuntu:~$ rfkill list all
0: acer-wireless: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: acer-bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: no
2: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
Fyksen
  • 303
8 Answers8
Further research, primarily here, suggests that simply loading the firmware will be ineffective. http://forum.notebookreview.com/networking-wireless/716325-intel-7260-a-6.html
I suggest you download this to your desktop: http://www.kernel.org/pub/linux/kernel/projects/backports/stable/v3.11-rc3/backports-3.11-rc3-1.tar.bz2 Right-click it and select 'Extract Here.' Now open a terminal and do:
cd Desktop/backports-3.11-rc3-1/
make defconfig-iwlwifi
make
sudo make install
Now reboot and tell us if your wireless is working.
I tested in Ubuntu 13.04 and it compiles perfectly and correctly drives my Intel 6200, but I don't have a 7260 so I can't test further. Fingers crossed! You definitely need the firmware.
Bruno Pereira
  • 74,715
chili555
  • 61,330
Although you didn't confirm it from dmesg, it appears you need and lack the required firmware. Here is a link from my Dropbox: https://dl.dropboxusercontent.com/u/58267392/iwlwifi-7260-7.ucode.zip Please download it to your desktop. Right-click and select 'Extract Here.' Now open a terminal and do:
sudo cp Desktop/iwlwifi-7260-7.ucode /lib/firmware/
sudo modprobe -r iwlwifi
sudo modprobe iwlwifi
Do you have a wireless interface now?
iwconfig
Does it connect? Are there any informative messages here?
dmesg | grep iwl
chili555
  • 61,330
according to http://wireless.kernel.org/en/users/Drivers/iwlwifi , it seems we need a kernel-upgrade; Ubuntu 13.04 use 3.8.0 by default, which can't support n7260
wait for Ubuntu 13.10 is another solution...
I'm upgrading my kernel now ;(
I upgraded to the kernel 3.11-8 and both of the network connections work 'out of the box'.
When upgrading you might have a warning such as firmware possibly missing with names of different files needed: I fixed it with apt-file search name_of_the_file and this for each file "probably missing".
Braiam
  • 69,112
In order that your wireless card be detected - you have to go to "System Settings" -> "Additional Drivers" and Activate (turn button from grey to green) for your card. On some RTL cards there can be 2-3 or more drivers (I had on my Dell Inspiron 6400) :( - in that case try to turn off one that is not working and turn one next one - until you found right one :(((. Eorked for me (was just 3 ;-))
Hopefully this will help
Dragan
I am using the same hardware as you
   description: Wireless interface
Kernel version is
$ uname -a Linux nanak-P570WM 3.11.0-13-generic #20-Ubuntu SMP Wed Oct 23 07:38:26 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
I am using Wireless since long.
Please install the above Kernel version from
http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.12-saucy/
It should work.
for solve install New Package:
wget -N "http://ftp.debian.org/debian/pool/non-free/f/firmware-nonfree/firmware-iwlwifi_0.40_all.deb";
sudo dpkg -i --force-all firmware-iwlwifi_0.40_all.deb;
sudo install -f;
reboot;
source : http://packages.debian.org/jessie/firmware-iwlwifi
ek0892
Ubuntu 13.10, It resolved for me by :
apt-get install linux-firmware
