I'm trying to understand the rational behind installing from software from source in Ubuntu 12.04. Obviously, I know I can download what I need from repos, but I want to develop a deeper understanding of Linux.
As a Windows users, when I download a program I double click it, and it installs into the
program files directory unless I specify otherwise. When I want to uninstall it, Windows has a tools that does that for me.
When I install a program in Linux, where does it install to? How do I uninstall it afterwards? Are there residual files left over? How would I tell if it's been fully removed?
For instance, I'm going to install LMMS (Linux Multimedia Studio) from source. I download and decompress the tar ball, and have a folder name lmms_XXX.tar (whatever).
The folder is now on my desktop with an install file. If I run the install file from that location, does it install into that folder? If so, can I move that folder to where ever I want? I want thinking about putting it in /opt/lmms
Pro Backup
  • 3,248
You might compile from source code if the program you want is not available in the repositories; if the latest version isn't available; or if you wanted to modify or patch the source code for a particular purpose.
Most but not all programs are installed to run from /usr/bin; some from /usr/sbin; some even elsewhere. When you compile form source code, the last few lines after you execute the install script will indicate where it installed.
To remove a program installed from the repositories:
sudo apt-get remove some_program
To remove the program and configuration files:
sudo apt-get purge some_program
To remove a program installed from source code:
cd Desktop/lmms_XXX
sudo make uninstall
There may be variations and the INSTALL file usually included with source code explains it.
Since source code is written for many kernel versions and many different Linux distributions, it doesn't always go perfectly.
Unless you are certain there is something you need in the tar.gz, I assume 0.4.15, I strongly suggest the repo version:
sudo apt-get install lmms lmms-common
It installs 0.4.14.
chili555
  • 61,330
