This is what Update Manager pops up with:
libc6: Depends: libc-bin (= 2.15-0ubuntu10.4) but 2.15-0ubuntu10.4 is installed
Depends: libgcc1 but it is not installed
Depends: tzdata but it is not installed
Edit:
sudo apt-get -f install
returns:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
apt-utils coreutils debconf debconf-i18n dpkg libacl1 libapt-inst1.4
libapt-pkg4.12 libattr1 libbz2-1.0 libdb5.1 libgcc1 liblocale-gettext-perl
liblzma5 libselinux1 libstdc++6 libtext-charwidth-perl libtext-iconv-perl
libtext-wrapi18n-perl perl-base tar tzdata xz-utils zlib1g
Suggested packages:
debconf-doc debconf-utils whiptail dialog gnome-utils
libterm-readline-gnu-perl libgtk2-perl libnet-ldap-perl libqtgui4-perl
libqtcore4-perl apt bzip2 ncompress xz-lzma
The following NEW packages will be installed:
0 upgraded, 24 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/9,304 kB of archives.
After this operation, 29.7 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
E: Cannot get debconf version. Is debconf installed?
debconf: apt-extracttemplates failed: No such file or directory
dpkg: regarding .../libgcc1_1%3a4.6.3-1ubuntu5_i386.deb containing libgcc1, pre- dependency problem:
libgcc1 pre-depends on multiarch-support
multiarch-support is unpacked, but has never been configured.
dpkg: error processing /var/cache/apt/archives/libgcc1_1%3a4.6.3-1ubuntu5_i386.deb (- -unpack):
pre-dependency problem - not installing libgcc1
E: Internal Error, No file name for libc6
W: Could not perform immediate configuration on 'multiarch-support:i386'. Please see man 5 apt.conf under APT::Immediate-Configure for details. (2)
sudo dpkg --configure -a returns
dpkg: dependency problems prevent configuration of libc6:
libc6 depends on libgcc1; however:
Package libgcc1 is not installed.
libc6 depends on tzdata; however:
Package tzdata is not installed.
dpkg: error processing libc6 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of multiarch-support:
multiarch-support depends on libc6 (>= 2.13-0ubuntu6); however:
Package libc6 is not configured yet.
dpkg: error processing multiarch-support (--configure):
libc6
