As the title says when I select UNetbootin as my OS I get an error saying that Windows failed to start. It advises me to repair using my Windows disc. Then I get this on the screen:
Windows Boot Manager
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:   1. Insert your Windows installation disc and restart your computer.   2. Choose your language settings, and then click "Next."   3. Click "repair your computer." If you don't have this disc, contact your system administrator or computer manufacturer for assistance.   File: \ubnldr.mbr   Status: 0xc0000007b   Info: The application or operating system couldn't be loaded because a required         file is missing or contains errors.
I am using Windows 8 and Ubuntu 13.04.
So I was already booting In legacy. On a lark I decided to try UEFI and that has made it so I cannot even boot windows after switching back to legacy. I get:
error no such partition
grub rescue >
From the boot menu I can enter either P2: TSSTcorp DVDWBD SN-406AB or P1: WDC WD7500BPKT-75PK4T0 or Bigfoot Boot Agent.
This is quickly going from bad to catastrophic. Please assist. I am in way over my head now. I removed the Ubuntu DVD and still no luck getting back into Windows.
Any advice on getting around this or understanding what the problem is would be appreciated.
karel
  • 122,292
  • 133
  • 301
  • 332
Dodd
  • 51
This happened to me before. You need to go into your BIOS and disable UEFI and enable Legacy booting. That's what I did and it worked perfectly finefor me.
Dat
  • 31
Ubuntu have messed the boot loader apparently. The fix I used when i had a similar problem is located here: Install Ubuntu next to Windows 8 (UEFI dual boot) (your question is a possible duplicate of that post)
These two lines did it for me:
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update sudo apt-get install boot-repair Now run boot-repair
Read the article and let us know if that helped or if our problem is related to that.
Not Amused
  • 888
  • 20
  • 38
