I have recently changed OS from Ubuntu 12.10 to 13.04. Then onwards my external HDD (mounted as VIVEK) became read only. When I try to create a new folder it shows an error msg as shown in figure.
Error Message
I have changed the ownership to me only but still when I use chmod 777 -fR /media/vivek/VIVEK, it is not effecting the read write and execute permissions.
Uneffected of chmod
when I try using sudo fsck -p /dev/sdb1 or sudo fsck.vfat -r /dev/sdb1 it is showing a message as "Currently, only 1 or 2 FATs are supported, not 0." When I check the properties of the hard disk, at the place of File System Format it is not showing either FAT32 or NTFS but blank.
No File System Format fsck error
Please help me out to get rid of this problem so that I can cut/copy/create new folders in my external HDD. BTW I am still able to do all these on the same external HDD when connected to any other system running on Windows.
Vivek
  • 36
When dealing with hard drive partition, and dealing with data in general, make sure that you have a current backup just in case.
You may consider something like Clonezilla.
I hate to be the one telling you this. For the first message, I/O Error is bad. It ususally means that a section of your drive is unable to read or write. In this case it seems like it's unreadable. Which means that sections of the drive are bad, which might cause you to start loosing data.
You could try FSCK. Unmount your disk and run the sudo fdisk -l command to find out the device name of the disk, and once you find it, run:
sudo fsck /dev/sdb1
for the second issue, try
sudo dosfsck -r -v /dev/sdb1
Hope that this helps.
Mitch
  • 109,787
