If you would be so kind to explain and answer my dilemma, I'd be grateful of all of you.
Here is the error:
Error mounting /dev/sda1 at /media/ubuntu/System: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999,dmask=0077,fmask=0177" "/dev/sda1" "/media/ubuntu/System"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda1': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
Problem: I cannot mount my System or "Windows" Drive. In the first place, it said i cannot boot windows, so i got Ubuntu instead. So after trying to get my 800gb Windows drive back, this error popped up. Any help would be wonderful.
Mitch
  • 109,787
Josh
Your Error indicates that you use either an hibernated Windows or Windows 8 with fast startup.
If you cannot startup Windows and want to mount the partition you need to open the Disks utility (in terminal 'gnome-disks'). There you need to go to the partition you want to use and change its Mount Options. In the Line with the Options "nosuid,nodev' etc you need to add the line "remove_hiberfile". With that line added you can safely mount the partition.
More Informations here.
Guest
Please cancel your hibernation function of your Windows OS. That is active by default. After that, you can mount your partitions.
You can also read Cannot mount NTFS partition in Ubuntu 13.04 and Ubuntu 13.04 is unable to mount a disk drive from ex-windows system or watch the video How to Disable hibernate in Windows 8.
Melebius
  • 11,750
ubuntu_tr
  • 665
