I'm using mktorrent, but I'm having problems with it since it doesn't hash the files in the directory for some weird reason...
I'm looking for a replacement specifically for command line
How about ctorrent?
sudo apt-get install ctorrent
ctorrent -t -u "http://tracker.example.com:6969/announce" -s example.torrent file_or_dir_to_upload
Transmission can do it:
$ ./transmission-create --help
Usage: transmission-create [options] <file|directory>
Options:
-h --help Display this help page and exit
-p --private Allow this torrent to only be used with the specified tracker(s)
-o --outfile <file> Save the generated .torrent to this filename
-c --comment <comment> Add a comment
-t --tracker <url> Add a tracker's announce URL
-V --version Show version number and exit
an example could be:
transmission-create -o /var/lib/transmission-daemon/downloads/files.torrent -c "My comments" -t udp://tracker.openbittorrent.com:80 ~/torrent/complete/my_file_or_directory_to_share.extension
you can find more documentation here
Description:
Create torrents via command line!
py3createtorrent is a comprehensive shell/commandline utility for creating torrents (Linux & Windows). It's a GPL-licensed Python v3.1 script.
Buildtorrent
sudo apt-get install buildtorrent
From synaptic:
Description: command line torrent creation program
buildtorrent is a torrent file creation program. Given an announce url and an input file or directory, buildtorrent generates an output .torrent file that can be used by torrent clients.
You can use torrenttools.
sudo add-apt-repository ppa:fbdtemme/torrenttools
sudo apt-get update
sudo apt install torrenttools
Create BitTorrent metafiles.
Usage: torrenttools create [OPTIONS] target
Positionals:
target <path> Target filename or directory
Options:
-h,--help Print this help message and exit
-v,--protocol <protocol> Set the bittorrent protocol to use.
Options are 1, 2 or hybrid. [default: 1]
-o,--output <path> Set the filename and/or output directory of the created file.
[default: <name>.torrent]
Use a path with trailing slash to only set the output directory.
-a,--announce <url>... Add one or multiple announces urls.
Multiple trackers will be added in seperate tiers by default.
Use square brackets to groups urls in a single tier:
eg. "--announce url1 [url1 url2]"
-g,--announce-group <name>... Add the announce-urls defined from an announce group specified in the configuration file.
Multiple groups can be passed. eg. "--announce-group group1 group2"
-w,--web-seed <url>... Add one or multiple HTTP/FTP urls as seeds.
-d,--dht-node <host:port>... Add one or multiple DHT nodes.
-c,--comment <string> Add a comment.
-p,--private <[on|off]> Set the private flag to disable DHT and PEX.
-l,--piece-size <size[K|M]> Set the piece size.
When no unit is specified block size will be either 2^<n> bytes,
or <n> bytes if n is larger or equal to 16384.
Piece size must be a power of two in range [16K, 64M].
Leave empty or set to auto to determine by total file size. [default: auto]
-s,--source <source> Add a source tag to facilitate cross-seeding.
-n,--name <name> Set the name of the torrent. This changes the filename for single file torrents
or the root directory name for multi-file torrents.
[default: <basename of target>]
-t,--threads <n> Set the number of threads to use for hashing pieces. [default: 2]
--checksum <algorithm>... Include a per file checksum of given algorithm.
--no-creation-date Do not include the creation date.
--creation-date <ISO-8601|POSIX time>
Override the value of the creation date field as ISO-8601 time or POSIX time.
eg.: "2021-01-22T18:21:46+0100"
--no-created-by Do not include the name and version of this program.
--created-by <string> Override the value of the created by field.
--include <regex>... Only add files matching given regex to the metafile.
--exclude <regex>... Do not add files matching given regex to the metafile.
--include-hidden Do not skip hidden files.
--io-block-size <size[K|M]> The size of blocks read from storage.
Must be larger or equal to the piece size.
Disclaimer: I am the author of this tool.
See the documentation for more information and examples.
