I tried to install cmake 2.8.11 on Ubuntu 13.04. I got cmake 2.8.11 source and during installing some errors happened. And Ubuntu installs cmake 2.8.10. Because of a lot of dependencies I am not able to install manually. Please suggest how I can install cmake 2.8.11 on Ubuntu 13.04.
I use a open source code, needs cmake 2.8.11 for accurate execution. I tried to install by the following commands:
tar -xzvf cmake-2.8.11.2.tar.gz
cd cmake-2.8.11.2.tar.gz
./configure
make
after ./configure:
-- Checking whether C++ compiler has '__int64' - no
-- Checking for C type size macros
-- Checking for C type size macros - compiled
-- Looking for sys/types.h
-- Check size of __int64 - failed
-- Checking whether char is signed
-- Checking whether CXX compiler has _atoi64 - no
-- Looking for connect in socket;dl
-- Looking for connect in socket;dl - not found
-- Looking for gethostbyname in c
-- Looking for gethostbyname in c - found
-- Looking for recv in network;dl
-- Looking for recv in network;dl - not found
-- Looking for getch in ws2_32;dl
-- Looking for getch in ws2_32;dl - not found
-- Looking for getch in winmm;dl
-- Looking for getch in winmm;dl - not found
-- Looking for idna_to_ascii_lz in idn;dl
-- Looking for idna_to_ascii_lz in idn;dl - not found
-- Looking for dlopen in dl
-- Looking for dlopen in dl - found
-- Looking for process.h
-- Looking for process.h - not found
-- Looking for features.h
-- Looking for features.h - found
-- Looking for include file stdio.h
-- Looking for 37 include files stdio.h, ..., sys/utime.h - not found
-- Looking for 37 include files stdio.h, ..., sockio.h
-- Looking for 37 include files stdio.h, ..., sockio.h - not found
-- Looking for 37 include files stdio.h, ..., sys/sockio.h
-- Looking for 37 include files stdio.h, ..., sys/sockio.h - not found
-- Looking for 37 include files stdio.h, ..., x509.h
-- Looking for 37 include files stdio.h, ..., x509.h - not found
-- Looking for 42 include files stdio.h, ..., idn-free.h - not found
-- Looking for 42 include files stdio.h, ..., idna.h
-- Looking for 42 include files stdio.h, ..., idna.h - not found
-- Looking for 42 include files stdio.h, ..., tld.h - not found
-- Looking for 45 include files stdio.h, ..., sys/filio.h - not found
-- Looking for stricmp - not found
-- Looking for strcmpi
-- Looking for strcmpi - not found
-- Looking for strncmpi
-- Looking for strncmpi - not found
-- Looking for inet_ntoa_r - not found
-- Looking for closesocket
-- Looking for closesocket - not found
-- Looking for getpass_r - not found
-- Looking for _strtoi64 - not found
-- Looking for strerror_r
-- Looking for idn_free - not found
-- Looking for idna_strerror
-- Looking for idna_strerror - not found
-- Looking for tld_strerror
-- Looking for tld_strerror - not found
-- Performing Curl Test HAVE_FIONBIO - Failed
-- Performing Curl Test HAVE_IOCTLSOCKET
-- Performing Curl Test HAVE_IOCTLSOCKET - Failed
-- Performing Curl Test HAVE_IOCTLSOCKET_CASE
-- Performing Curl Test HAVE_IOCTLSOCKET_CASE - Failed
-- Performing Curl Test HAVE_O_NONBLOCK
-- Performing Curl Test HAVE_O_NONBLOCK - Success
-- Performing Curl Test HAVE_SO_NONBLOCK
-- Performing Curl Test HAVE_SO_NONBLOCK - Failed
-- Performing Curl Test TIME_WITH_SYS_TIME
-- Performing Curl Test TIME_WITH_SYS_TIME - Success
-- Performing Curl Test HAVE_O_NONBLOCKHAVE_GETHOSTBYADDR_R_5
-- Performing Curl Test HAVE_O_NONBLOCKHAVE_GETHOSTBYADDR_R_5 - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7 - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8 - Success
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_5_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_5_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8_REENTRANT - Success
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3 - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5 - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6 - Success
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6_REENTRANT
-- Performing Curl Test HAVE_INET_NTOA_R_DECL - Failed
-- Performing Curl Test HAVE_INET_NTOA_R_DECL_REENTRANT
-- Performing Curl Test HAVE_INET_NTOA_R_DECL_REENTRANT - Failed
-- Check size of curl_off_t - done
-- Performing Test curl_cv_recv
-- Performing Test curl_cv_recv - Success
-- Performing Test int recv(int, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, int, unsigned int) (curl_cv_func_recv_test) -
Failed
-- Performing Test int recv(int, void *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, size_t, unsigned int) (curl_cv_func_recv_test)
 - Failed
-- Performing Test int recv(int, char *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, int, unsigned int) (curl_cv_func_recv_test)
 - Failed
Failed
-- Performing Test int recv(ssize_t, void *, unsigned int, int) (curl_cv_func_recv_test)
 - Failed
-- Performing Test int recv(ssize_t, void *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, unsigned int, int) (curl_cv_func_recv_test)
 - Failed
-- Performing Test int recv(ssize_t, char *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, socklen_t, unsigned int)
-- Performing Test int recv(SOCKET, void *, unsigned int, int) (curl_cv_func_recv_test)
- Failed
-- Performing Test int recv(SOCKET, void *, unsigned int, unsigned int)
-- Performing Test int recv(SOCKET, void *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, size_t, unsigned int)
-- Performing Test int recv(SOCKET, char *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test curl_cv_send
-- Performing Test curl_cv_send - Success
-- Performing Test int send(int, const void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, int, int) (curl_cv_func_send_test) - Failed
-- Found ZLIB: cmzlib
-- Found BZip2: cmbzip2 (found version "1.0.5")
-- Looking for BZ2_bzCompressInit in cmbzip2
-- Looking for BZ2_bzCompressInit in cmbzip2 - not found
-- Performing Test HAVE_DIRENT_H
-- Performing Test HAVE_DIRENT_H - Success
-- Looking for include files sys/types.h, acl/libacl.h
-- Looking for include files sys/types.h, acl/libacl.h - not found
-- Looking for include files sys/types.h, ctype.h
-- Looking for include files sys/types.h, ctype.h - found
-- Looking for 3 include files sys/types.h, ..., copyfile.h
-- Looking for 3 include files sys/types.h, ..., copyfile.h - not found
-- Looking for 3 include files sys/types.h, ..., direct.h
-- Looking for 3 include files sys/types.h, ..., direct.h - not found
-- Looking for 5 include files sys/types.h, ..., ext2fs/ext2_fs.h
-- Looking for 5 include files sys/types.h, ..., ext2fs/ext2_fs.h - not found
-- Performing Test HAVE_WORKING_EXT2_IOC_GETFLAGS
-- Performing Test HAVE_WORKING_EXT2_IOC_GETFLAGS - Failed
-- Looking for 26 include files sys/types.h, ..., sys/acl.h
-- Looking for 26 include files sys/types.h, ..., sys/acl.h - not found
-- Looking for 26 include files sys/types.h, ..., sys/cdefs.h
-- Looking for 26 include files sys/types.h, ..., sys/cdefs.h - found
-- Looking for 28 include files sys/types.h, ..., sys/mkdev.h
-- Looking for 28 include files sys/types.h, ..., sys/mkdev.h - not found
-- Looking for 28 include files sys/types.h, ..., sys/mount.h
-- Looking for 28 include files sys/types.h, ..., sys/mount.h - not found
-- Looking for 32 include files sys/types.h, ..., sys/statfs.h
-- Looking for 43 include files sys/types.h, ..., windows.h - not found
-- Looking for 43 include files sys/types.h, ..., wincrypt.h
-- Looking for 43 include files sys/types.h, ..., wincrypt.h - not found
-- Looking for 43 include files sys/types.h, ..., winioctl.h
-- Looking for 43 include files sys/types.h, ..., winioctl.h - not found
-- Performing Test SAFE_TO_DEFINE_EXTENSIONS
-- Performing Test SAFE_TO_DEFINE_EXTENSIONS - Success
-- Looking for MD5Init in md
-- Looking for MD5Init in md - not found
-- Looking for _CrtSetReportMode
-- Looking for _CrtSetReportMode - not found
-- Looking for chown
-- Looking for getpid
-- Looking for getpid - found
-- Looking for getvfsbyname
-- Looking for getvfsbyname - not found
-- Looking for lchflags
-- Looking for lchflags - not found
-- Looking for strncpy_s
-- Looking for strncpy_s - not found
-- Looking for _ctime64_s - not found
-- Looking for _fseeki64
-- Looking for _fseeki64 - not found
-- Looking for _get_timezone
-- Looking for _get_timezone - not found
-- Looking for _localtime64_s
-- Looking for _localtime64_s - not found
-- Looking for _mkgmtime64
-- Looking for _mkgmtime64 - not found
-- Looking for cygwin_conv_path
-- Looking for cygwin_conv_path - not found
-- Performing Test MAJOR_IN_MKDEV - Failed
-- Looking for EFTYPE
-- Looking for EFTYPE - not found
-- Looking for EILSE
-- Performing Test HAVE_STRUCT_TM___TM_GMTOFF
-- Performing Test HAVE_STRUCT_TM___TM_GMTOFF - Failed
-- Performing Test HAVE_STRUCT_STATFS_F_NAMEMAX
-- Performing Test HAVE_STRUCT_STATFS_F_NAMEMAX - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIME
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIME - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIMESPEC_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIMESPEC_TV_NSEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIMESPEC_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIMESPEC_TV_NSEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIM_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIM_TV_NSEC - Success
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_N
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_N - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_UMTIME
-- Performing Test HAVE_STRUCT_STAT_ST_UMTIME - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_USEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_USEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BLKSIZE
-- Performing Test HAVE_STRUCT_STAT_ST_BLKSIZE - Success
-- Performing Test HAVE_STRUCT_STAT_ST_FLAGS
-- Performing Test HAVE_STRUCT_STAT_ST_FLAGS - Failed
-- Performing Test HAVE_STRUCT_STATVFS_F_IOSIZE
-- Performing Test HAVE_STRUCT_STATVFS_F_IOSIZE - Failed
-- Checking _FILE_OFFSET_BITS for large files
-- Checking _FILE_OFFSET_BITS for large files - not needed
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBC
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBC
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBMD
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBMD
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBMD -- not found
-- Check if the system is big endian
-- Searching 16 bit integer
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Using unsigned short
-- Check if the system is big endian - little endian
-- Looking for elf.h
-- Looking for elf.h - found
-- Looking for a Fortran compiler
-- Looking for a Fortran compiler - /usr/bin/f95
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - not found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found
-- Found unsuitable Qt version "5.0.1" from /usr/bin/qmake
-- Performing Test run_pic_test
-- Performing Test run_pic_test - Success
-- Configuring incomplete, errors occurred!
Error when bootstrapping CMake:
Problem while running initial CMake
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
hadizs
Package Information
CMake Dependencies
Installation of CMake
Install CMake by running the following commands in terminal:
cd <DOWNLOADS-DIRECTORY>
md5sum cmake-2.8.11.tar.gz        #optional, to check MD5 sum
tar -xzvf cmake-2.8.11.tar.gz
cd cmake-2.8.11
./bootstrap --prefix=/usr --system-libs --mandir=/share/man --docdir=/share/doc/cmake-2.8.11
make
make test                         #optional, to test the results
sudo make install
Source: http://www.linuxfromscratch.org/blfs/view/svn/general/cmake.html.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
