I'm trying to install CGIProxy on my Ubuntu server and according to the instructions I have to:
Copy the file
nph-proxy.cgionto your Web server somewhere, but not at the top Web directory, or else it will be easily discovered.Change the file's permissions to be executable. On Unix and Mac, you can do this with the command
chmod +x nph-proxy.cgithere are other ways.
In the directory where you copied
nph-proxy.cgi, run the command./nph-proxy.cgi install-modules(or in Windows,
perl nph-proxy.cgi install-modules). This installs the optional Perl modules to e.g. let you visit secure sites. If you can't run this as root/administrator, it will still work, but see the instructions displayed at the end after all the scrolling text (which you can ignore). If it asks you any questions, you can just hit Ret.
I'm at step 3 but when I run the command
I get the following:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:en",
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
I'm still pretty new to linux so I'm not sure what the issue is here, I've tried to run the command with sudo but still the same error.
Any help is greatly appreciated, thanks!
