I want to modify wineprefix installed with playonlinux using Winetricks.
enzotib
  • 96,093
You could stick
export WINEPREFIX=/home/$USER/.playonlinux/path/to/prefix/
in ~/.bashrc (and then run source ~/.bashrc to load it the first time if you're already in a terminal)
Or just prefix your winetricks commands like:
WINEPREFIX=/home/$USER/.playonlinux/path/to/prefix/ winetricks blah blah blah
I don't use POL but I have in the past and I rather thought there was a button or menu item that let you run various winetricks things without having to run it manually. I'm probably wrong but give it a look.
Oli
  • 299,380
