I need to configure a Canon IR C3380 printer. I have not found drivers for it (it says is not necessary). Can you tell me which driver or protocol I must install?
thank you!
bain
  • 12,200
Go to the following site:
http://software.canon-europe.com/products/0010366.asp
then choose the OS (in your case I am assuming you are using Ubuntu, if yes then you can choose Linux) then select your preferred language and click on submit.
Based on your Ubuntu installation choose either 32bit Deb or 64Bit Deb.
kos
  • 41,268
Nemesis
  • 133
